RC cable slider replacement
Allan L
So this is probably a stupid question but here goes. I just received my Mavic Pro today. I see that it came installed with an RC cable and slider. However I need to change that because I have an Android phone that uses a "c" type port. Anyway the Mavic comes with a replacement cable "c" type and the requisite slide that comes with it. I just can't figure out how to remove the "old" slider and then how to insert the new slide for the new "c" cable. I would have thought this was a fairly elementary procedure for DJI to have some information on , but when I contacted them, no one could help. I'm sure there is someone on this forum that knows how to do this. It's got to be fairly common.
The slider just pops out of the arm when you push on it. You might find it easier to use the side cable without the slider installed.
Agree with ths, usually seems easiest to completely remove cable, attach to phone, put in place then attach to controler.
All the slider does is get in the way and make it hard to do.
gomezstatiq
