So when I found out you can record audio from the controller I was excited.. but then found out it doesn't feed back up to the drone and make its way on that SD card but you have to fix in post on the controller SD.. so then disappointed. So bigger question then. If you do record audio and use the HDMI out.. is the audio on that feed or only the drone video ?
