Good Morning.
I'm facing a severe poblem from my Remote Controller on Mavic Pro.
Mavic Pro Model M1P
Information from the DJI ASSISTANT 2 :
-RC Software Version : V01.04.0500
-Aircraft Software Version : V01.04.0500
Phone : Iphone 8 (or Ipad) with DJI GO 4 App V4.3.32
First here are the symptoms :
HISTORY :
Since many months, the RC and AC have hard time linking together, sometimes I have to restart both of them 5 times and be lucky they pair...
Last time I flew (26/02/2020), in a middle of the flight the RC lost signal (due to "weak antenna" or " strong interference" or "IMU...", didn't have time to read because the whole DJI GO4 App went dark screen to RC signal Lost).
The AC returned to home, I recover the preview/menu on the phone but I couldn't give any command to the Aircraft.
The app keeps on giving me "Command Timeout" message for any of my commands. Impossible to even land ! After 5 min I had to take out the AC battery in flight !
Went back home, watch the video I took, and as I was connected to a Wifi : the AC/Remote asked me to update the software to the latest version... I approved.
The update seemed successful.
NOW :
! The RC doesn't want to connect to the Aircraft !
1) When I'm not "lucky" : the Red warning "AC disconnected" message shows up on the App. Nothing I can do...
2) When I'm "more lucky" (or sometimes immediately after binding them via the DJI GO4 App) :
- I turn on the AC... then I turn on the RC... and they briefly connect together :
- I see on my App the preview, then immediately Red warning message : "RC signal Lost"...
- HOWEVER the App still showing "live" image of the camera, for about 10 sec...
- Then the message Red warning "AC disconnected" pop up briefly (1 sec) and screen goes black
- Then the Grey message "Disconnected" pop up briefly (1 sec)
- Then the RC vibrates and starts writing a digital message... "RC...S..." that does not reach the end...before getting back to "Connecting_"
- Then back to "RC signal Lost" with preview... 10 sec... "AC Disconnected"... "Disconnected"... Etc...
I read all the forum. And tried all the tricks...
With the DJI Assistant 2 : Downgrade/Upgrade/Reset to default factory... always end up "FAIL"
With the DJI Go Pro 4 : I used the binding fonction more than ever... it only allows me to be "more lucky" (cf above). I also cleared the Cache of the device. I also connected my account. I also deleted the app and reinstalled it.
With the SD card : I formatted it or try fly without it
With the cable : used the side port and the bottom port... with 2 different cables and 2 different devices.
With the Aircraft : I removed the SD card before turning it ON. I also switch from RC... to WIFI. On wifi I can fly the Aircraft. Thus I reset everything via the menu : the IMU... the gimbal... etc...
From the last sentence above, it seems my RC is bricked, the problem clearly comes from that device... since I can fly under Wifi.
However the option to fix a RC are limited : I tried DJI assistant 2... all reset failed... I tried draining the RC battery to 0... didn't solve anything.
Please... let me know if anyone ever face this problem (havent found any thread about it). Any solution... I'm a bit desperate.
Thanks a lot in advance.
Mavic Pro Model M1P
HISTORY :
NOW :
