RC USB Socket
No probs!
First pic is the cover I use. Snaps onto the side with magnets and covers the screen when not in use.
Second is how it holds the iPad, quite a close fit with a little thin rubber pad in there to protect the iPad and grip better (grips quite well)
The last is the iPad mounted and it resting against my stomach and the pic is looking straight down from my eye line to show exactly what I see.
Very simple design, the neck strap works perfectly for one handed stuff like auto take off or land with hand launch / catch and it all holds on very well and is easy to attach. I put the brackets onto the iPad then slide them into the controller arms and they lock into them firmly.
Thanks. Would you say the thickness of that rubber pad possibly equivals the thickness of a thin silicone case?
The rubber is thin, really thin. Prob less than 0.5mm.
However if you have a thin silicone case you could peel them off and if you still had not enough room you could file the opening a little more, plenty of material there.
These I should add are simply 3d printed so are a little rough and if you really wanted could do with some sanding to make them look really nice. Personally I go for function over fashion so have not bothered. One day maybe...
Totally agree w/you. And as i figured, there is a little bump one can sand and find some more space for the tab to go inside.
Thank you.
Reactions: SeaComms
Teewata
