Recalibrate gimbal after replacing motherboard .
h1s0k4
I have a problem with my drone and the shop said that I have to replace the motherboard. I ordered one but some people said that the gimbal will be tilted and can not be calibrated by DJGO or DJI assistant .
Any one did that before ? Any suggestion ?
There really is no motherboard in the Mavic, there is the FC ESC board and the core board. Can you start from square one and tell us what happened that caused you to replace the board in the first place? I have done hundreds of them.
Oh sorry , that was my Mavic Air , not the Mavic Pro .
Okay , I will try when I receive my board frome ebay .
I did it several times :) not too difficult with youtube video
Did you take apart your Air yet? If not, it's a good time to do it while you wait for the part. Make sure you label all the screws. ;)
I got the board today and I've just replaced it and as my friend said , it is tilted . I use DJGO4 to recalibrate it but wasn't sucessfull . I can not use the DJI assistant to calibrate it also .
Anyone was in the same situation ? Any suggestion ?
did you find a solution? I'm having the same problem when i changed the gimbal
elitewikipublishers
