Recommended charger for mini 4 pro and all the accessories?
To maximize charging efficiency, one would want to have 3 battery chargers rather than a single 3 bank.
The three bank is internally regulated to only provide enough amperage to charge the battery at maximum efficiency to maintain battery life. And it only does that to each battery at a time. It doesn't charge all three at once regardless of how awesome a power supply is.
And charging the controller separately is a bonus with the power bank since it will charge from the battery bank only after each battery is charged.
So, single bank chargers will charge faster overall.
This one I have does two batteries at a time in 35minutes. He has others that do same in different configs. This PD power adapter works great. Only gets 110°F after prolonged use. The two batteries charged at the same time barely reach 90°F.
Wattage on chargers is a capacity, not a spec of what comes out of it regardless of the load. Even older "dumb" chargers only deliver as much power to a load as it will draw on it's own.
Newer DJI products use a protocol called Power Delivery, where the charger and the load are both "smart", communicate with each other and negotiate a power profile. So the load knows what the charger can do, and asks for no more.
When selecting a PD charger the important spec is overall power capacity, maximum power per port, and power per port When multiple ports are in use.
That said, my advice to people is to bite the bullet and invest $80-100 bucks in a good 200W multiport that can do 100W simultaneously on two ports. It will be all you need for many devices for a long time. You can charge drone batteries, goggles, and RCs all at once.
I have this one, U$69 at Amazon. The display is a nice feature...
Has a very flexible multiport power distribution:
Hmm... that one isn't available anymore.
I just grabbed a mini 4 pro with one battery and 11 flights totalling about 40 minutes flight time for $200. It's way smaller than my M3P. I don't know why I thought it would be bigger....
Reactions: qadsan
OldGitRay
