Recorded video quality on phone
Sportflyer
I wanted to verify when you pick "normal" under image transmission will it live feed and record to your phone in 720 and then if you switch to "HD" will it then live feed and record in1080?
Is this correct?
Thanks!
Yes it will. If your using DJI GO 4.0, it will save 720p videos in yur DJI/Record Folder until the cache ammount
you set is reached.
For memory, the 1080 cache mode is a bit broken (limit of the camera).
It can only do 1080i
osje
