Reflection
tnpaul
There is a reflection that shows in the lower to mid part of the screen when flying it is bow shape. Any guesses on what this is and how to solve it. It will even show up in the pictures.
If the gimbal cover is on, then you'll need to remove it. If it's not on, then please post a sample photo so we can see what you're describing.
Yes do you fly with out it and is there a problem to take it off
A few people fly with it on. At certain times of the day it will cause the glare you are experiencing. It is OK to fly with out it most people do.
The Gimbal cover (and clamp) should be removed before flight, as not only does it cause camera glare, but it also stops airflow through the vent behind the gimbal assembly, which has a fan to keep the electronics cool.
artyboy
