B boxergirl New Member Joined Oct 23, 2019 Messages 1 Reactions 0 Age 64 Location Bridgewater Oct 23, 2019 #1 Has anyone had a problem with their remote controller failing to charge?
Starz Well-Known Member Premium Pilot Joined Dec 26, 2016 Messages 5,643 Reactions 4,708 Location Arizona Oct 23, 2019 #2 The charge port can be damaged if you aren’t careful. not uncommon. Look and see if it looks normal inside where you plug it in.
D Deleted member 3792 Guest Oct 24, 2019 #3 You can only connect the USB-micro A in one way properly, the contact compartment is square and therefore it’s possible by force to do it the wrong way with broken circuit as a result. Be very careful wich way is the right way to connect it.
