Remote won't charge.
garrion
Haven't flown in a while. Can't update because battery too low, and will not charge. Any suggestions. HELP
Try turning the battery on while on the charger.
Reactions: dirkclod
Can you power on the rc while charging it ??
You can then connect the RC to your mobile device with the lower USB port while charging from the side port.
It is possible to replace the battery in the RC if you are good with taking things apart.
You can see the RC battery here :
Jump to 4:50 to see the battery
marcusjohn3684
