Replacing notch on rear arm
Skeye
Hi there,
Had anyone tried replacing this plastic notch that keeps the rear arm in position?
One of those is a bit deformed after a mild crash, what now makes that arm a bit lose when extended :(
Regards,
On top. One side was cracked, and the other side was bending upwards.
Reactions: M K
I super glued mine very carefully as it was cracked underneath that little ledge. It's as strong as ever now and even without it the ledge the arm seems to have an upper internal restraint in the spring mechanism. When Super gluing make sure to keep pressure on it but rotate the arm to ensure it doesn't get glued up.
Reactions: mereflyer
nikt_elo
