RTH settings RC Pro, 2 drones
BaldyBoyBilly
new jersey
I use the rc pro on an air2s and Mavic 3 pro.
When setting the return to home command on one of the drones (while connected to rc pro), does that command also get applied to the other drone when it is connected to the rc pro?
Or, does each drone have its own unique rth settings…so I can change rth on one drone and not affect the other?
The RTH settings are stored in the drone.
They have to be so the drone can return if signal is lost.
So if you change the setting in one drone, it won't carry across to another.
But DJI has changed the RTH behaviour for recent models from the standard behaviour they used for years in the older models, so check the manuals for your drones to understand how RTH works for them.
They might not be the same.
Reactions: 3rdof5 and msinger
Appreciate your clarification. Makes sense:)
stephy_gl
