SC - Quick Access Gimbal Level
EricJT
Toronto ON
I know there is a button combination for the M2P controller to attain quick access to the gimbal level function (right custom button + right control wheel).....is there anything comparable for the SC without having to go through the SC's menu system?
By default, the right button on the back of the Smart Controller will reset the gimbal. One press points it straight down and the next press brings it front and center. If you have yawed the gimbal, not sure if the first press of the button will bring it center.
As I recall you can program these buttons. The left one turns the bottom light on/off.
You can also program the bottom left button for Gimbal re-center and yes it will re-center if the camera is yawed
I suspect I wasn't clear enough on my original post....what I am trying to accomplish is to level/adjust the M2P's gimbal when the horizon is not level in the camera view. Nothing to do with moving the gimbal down or up.
I have watched videos and read about the button combination when using the standard controller with the M2P but have not found the same approach when using my Smart Controller. I am able to go into the settings (upper right 3 dots), gimbal settings, adjust gimbal, etc. Just wanted to check if there is a shortcut.
Thx.
nikt_elo
