SD card full warning
BaldyBoyBilly
new jersey
When powering up Mavic 3 pro and rc controller, a message appears which states SD card full.
This has been happening for months. The cards are not full and after a few minutes the message goes away.
It doesn’t affect usage but if anyone knows how to clear it, I’d be grateful.
Which SD card - the one in the drone or the one in the controller? Whichever one, I would try reformatting the card first and if that doesn't cure the problem, install/reinstall the latest firmware on whichever device is using that card.
Reactions: Erk1024
I agree with @tstr14, formatting the card with the drone seems like a good thing to try.
Reactions: MARK (LI)
Cards can go bad or weird. If formating does not solve the issue for good, replace the card. Cards are not expensive these days and not worth stressing about loosing important data on an unreliable card.
Reactions: Erk1024
@BaldyBoyBilly
Might also consider getting one of the known good / compatible micro ssd cards. Here are a couple:
PNW_Aerials
