SD card needed?
bmoore1118
I just got a classic and upgraded from a air 2s. I still have my old micro sd card and I have a 128GB Samung Pro card. It has a write speed of 130mb/s. With the classic having a higher write speed would this one be ok or should I upgrade?
If it's Pro Plus or Pro Ultimate then you'll be fine.
Reactions: GadgetGuy
Install the SD card, use a few times on something non-critical and see if you get any errors. I have used all sorts of cards over time and the only time the speed made much difference was in getting the data off the card onto the desktop for processing. I know you can find a combo that wont work but I bet you will be fine with what you have.
Why not just take it out in your back yard put it into the air an try it out, filming both stills and video>
Dale
Reactions: Nanny Ogg
The drone will tell you if the card is not suitable for the drone.
I would simply insert the card and try to record video and stills. Should take less time than asking- a few moments.
If the card you insert is too slow, the drone will show a warning in the app that the card is Too Slow, without even trying to capture imagery..
Fessy
