SEM IMAGEM
ROMULO MARTINELLO
Lucas do Rio Verde - MT
Boa tarde,
Estou com um problema no mavic pro.
Quando ligo o controle e o drone, ele faz um som contínuo , pilílíííííííííííííííí, e a imagem trava no celular. os comandos da câmera não funcionam, e o ícone do gimbal não aparece nas configurações.
Ja troquei cabo flat, cabo de video e fiz limpeza na placa. Nada resolveu. Estou pensando que trocar a placa, porem, não tenho certeza se será isso mesmo.
Translated by moderator->
Good afternoon,
I have a problem with my mavic pro.
When I turn on the controller and the drone, it makes a continuous sound, lines, and the image stuck on my phone. camera commands don't work, and the gimbal icon doesn't show up in the settings.
I already changed the flat cable, video cable and cleaned the board. Nothing resolved. I'm thinking about changing the board, but I'm not sure if that will be the case.
It's hard to know for sure, but that sounds like a board issue to me. Since you've already swapped out the cables, I would go ahead and try swapping the board.
Phly858
