Shapeways Sony Action camera mount
Sorry but doesn't this defeat the purpose of buying a Mav Pro? It has a fairly decent camera as it is.
If I was going to do this I would of brought a far cheaper drone for it.
Not to mention no gimbal or stabalzation.
The video quality would be awful!
It would be like the original Phantom with no gimbal.
Don't waste your time!
Actually, the as long as the frame is stiff, a drone doesn't know if the weight is above or below, just whether it's forward or rear...the force against it is straight down no matter if it's on top or bottom...
No stabilization ... No camera control ... Intense battery drain and probably 5 minute flight time ...... sounds like a real winner.
There are two compasses. One in front one in the rear. CG looks like it'll be way off with that camera on there. Even if you get it to CG perfect the motors will still be working quite a bit harder due to all the excess weight. Your motors will be working harder, your battery will be working harder, and your flight times will go down, you may get overcurrent warnings. I've got to ask why the extra camera?
onlinecricket88
