Smart Controller for Mavic Air 2
I've got 10 flights on the smart controller with my MA2. I started with a MA in 2019, then added the MA2 in August. The MA2 smartphone controller was a major disapppointment (taking RTH control with no warning, teeny battery meter, etc). So, I hated to spend the money for the smart controller, but I had already used one MA2 Care Refresh and I did not want to be buying a new MA2.
Anyway, the smart controller is all good so far. My next test will be to exhaust the battery and let it come home on its own, probably from 500 ft away at 200 AGL.
Reactions: Crashdummytest
Maybe a safer test would be to turn your SC off, rather than exhaust the battery
Good idea! I'll do that test separately. Thanks.
Thanks Invisible Name & Tom29928 for the feedback. Hate to be flying and the controller goes haywire and lose my drone.
I'm doing small flights also 25-50' altitude and 300-400' distance right now, with no trees or wires around.
Without mention the simplicity and convenience when you go flying. You can be in the air in 1 minute or less.
I love my Smartcontroller it´s like night and day compared to the original controller/smartphone or iPad ?:cool:?
I understand that the SC is nice but I can't see it being the difference of night and day vs. the Ipad Mini 5. Hard to beat the Ipad mini 5.
Reactions: GadgetGuy
I pad Mini 400 nits (once is hot will decreases) VS Smart controller sustainable 1000 nits because has an internal fan.
That makes it much better than even my Ipad Pro 11 that s 500 nits.
For screen size, I give the iPad the win.
Not putting down the Smart Controller, but getting in the air with the regular A2 controller is not exactly tedious, especially considering that unlike the crab claw controllers of other models, I don’t even have to remove my phone case. I noticed one of the new iPhone models has 1200 nits of brightness.
Reactions: DannyBhoy
Sounds like we have a new Olympic event. Lets see who can get in the air the fastest. If every starts doing that we are going to have a lot of crashed drones. Take your time and be safe no matter what controller you use.
Peak brightness in HDR mode. only 800 max brightness and is not sustainable. This is the same display as the iPhone 11 basically and testing demonstrates that is more a 680 nits after 2 minutes and a half in max brightness. If you sum you will be flying in sun will be even less because of the heat.
source: iPhone 12 Pro and 12 Pro Max - Technical Specifications
Both models:
  • HDR display
  • True Tone
  • Wide color (P3)
  • Haptic Touch
  • 2,000,000:1 contrast ratio (typical)
  • 800 nits max brightness (typical); 1200 nits max brightness (HDR)
  • Fingerprint-resistant oleophobic coating
  • Support for display of multiple languages and characters simultaneously
Reactions: BamaBomber
This is call convenience. If you don't mind the setup time and carry extra stuff I will go with my Ipad 11 Pro. I use both. When i hear the train coming to be recorded believe me the smart controller faster setup win all day long.
Very Nice!
Flown over 25 flights with SC and MA2 without any issues, over water and over rough terrain with no signal loss. Thought I would have difficulty reducing screen size from iPad mini 5 on IOS down to SC screen (Android) but the extra brightness compensates for that. I have fitted one of the SC rubber covers with the partial sunshade on it along with a lanyard and it is secure and very easy to handle.
I have also found a use for my original dji goggles by connecting them directly to the hdmi outlet on the SC to allow anyone with me (grandchildren) to watch the flight FPV.
The SC allows very quick set up and fly, no wires, no brackets, just up and away.
I discovered this today - tap the battery level icon at the top of the sc screen, and it displays time until RTH, until Forced Landing, and until Battery Depleted. The pop-up display stays on the screen and updates. Tap it to hide it. I love it!
Reactions: Phantomrain.org
Nothing beats the Smart Controller in the Rain or the Snow or the extreme heat or cold even hail for that matter.
Considering how many flights we have on the Smart Controller on both the Mavic 2 and the Mavic Air 2 in the Pouring Rain.
Not to mention how well it does from flying inside the car, and if you happen to have a Camera monitor its an instant HDMI hook up.
I cant tell you how many times I caught myself with low battery on the Iphone while making a video when I was flying the Air 2 but
that never happens on the SC. :)
Phantomrain.org
Gear to fly your Air 2 in the Rain and Float on Water.
Espletico
