SOLUTION TO ANDROID DEVICE CHARGING FROM RC
Yousuf110
Hello guys,
I found the solution to stop your Android device from charging from your RC's battery, therefore draining your battery.
1. Download an App called Battery Charge Limit ,from playstore, your phone will need to be rooted.
2. Check your phones battery level, on the app set the charge to lower than that amount and it will automatically stop charging while you are plugged into controller.
3. Enjoy longer RC battery times ;)
If you need help let me know.
Update: My RC's battery level has dropped 3% in 10 minutes using this method, while also being connected via my android phone.
Before, it would drop 10% in 12 minutes...
Rythorne
