Some tips for better Mavic pro video
Parthpanchal
  • Change your camera from Auto to Manual
  • Settings: Set White Balance from Auto to either Sunny or Cloudy depending on the day (Prevent shot blow-out)
  • Settings: Select custom color style. -1 -1 -1 (Sharpness, Contrast, Saturation) Makes the image flat so you can play around with the image in post
  • Color Profile: Either D-Log or D-Cinelike
  • Settings: Enable Histogram to gain understanding of image - Try to obtain bell-shaped curve.
  • Settings: Enable Overexposure Warning. Enables Zebra Pattern in areas of over-exposure
  • Settings: Enable Grid Lines. Allows for visual representation to support rule-of-thirds.
  • Use "Press and Drag" to control the gimble
  • Shoot in Cinematic Mode ABCya Adam4Adam POF
  • Back Right Custom Button + Scroll Wheel on the controller will adjust the tilt
  • Advanced Settings: Set Gimbal Pitch Speed to 10. Smooths movement of gimbal
  • Advanced Settings: Set Gimbal Smoothness to 20. Smooths movement of gimbal
Reactions: benosa562
No members online now.
kaidoestech
