Mavic 4 Pro Specs, What do we think about photography with it?
This all is seriously disappointing. Not only the typical deceiving marketing buzzwords, but to only increase the res by 5 mpxl in a relatively same size sensor is a low blow to devoted DJI drone photographers like myself. A 40 mpxl sensor should be offered as an option. Had they teamed up with (or got bought) by Fujifilm instead of Hassy, then there would be the XT-5 40 mpxl sensor in there now. Just bad news.
I agree. It seems they only care about video users. High quality photography seems much less important to them. Even the Inspire 3 with its better sensor, doesn’t offer all the features we need. Let’s hope the images in this M4 are better than the M3.
Inspire line-up has always been geared towards video. The AA filter in front of the sensor in the flagship X7 camera was way too strong and smeared fine details in photos. It was all about achieving the coveted "cinematic look". DJI never cared much about achieving sharp from corner to corner photos by their drones. But by saying that the M3 serie with the M43 sensor in the Hassy camera can produce pretty decent photos when its DNG files are carefully and skillfully processed. I do not expect any meaningful improvement in IQ from the M4P.
Reactions: wisefish
We are spoilt as photographers with high resolution sensors that can also shoot video but for a flying camera it's a trade off.
A camera doesn't have to provide power to four rotors and a sensitive gimbal while transmitting a low latency 1080, 60fps image over a long distance while simultaneously accepting control signals while continually monitoring its position using GPS and proximity sensors.
Stick an APS-C, 40 Mpix sensor in a drone the size of a Mavic and you would have to seriously upgrade the internal processor and seriously beef up the cooling system to cope with the massive amounts of data conversion (means heat) needed. Otherwise it would be a flying Canon R5 that would over heat after 10 mins if the battery even lasted that long.
I don't think they've have any problems fitting an APS-C sensor if they wanted to if they ditched the telephoto cameras since you just need to look at the small and cheap APS-C cameras (or even the QX1 module and that's without a more compact fixed lens) are compared to the micro 4/3 cameras, there's not much of a size difference nor any significant processor or cooling requirements. The R5 is a much larger FF sensor not APS-C.
I think the simpler answer as mentioned above is that DJI are more focused on the video side understandably and while it's not the best sensor, a 4/3 sensor is still a decent one for photography and much better than 1/2.3in or 1/1.3in sensors. Ultimately whatever the reason it doesn't have a larger sensor so that's that.
Reactions: Gazwas
It's not the size of the sensor but the number of pixels for high resolution photography that is the problem.
DJI will never make a photo only drone so you are faced with the fact that its much easier and a lot less overhead if it's 1:1 readout of the sensor resolution rather than binning or over sampling the 18 MPix required for 6k out of a 45+ MPix sensor.
I do agree to a point on the tele cameras though. The long tele does feel like a gimmick especially with the tiny sensor they use. The ideal for me would be a two camera set up like on the Air 3 but using an APS-C for main and M43 for short tele.
Reactions: Mrktn
It's not the number of pixels that are the issue for photography, while more is better what's more important is the dynamic range and the high iso noise. An APS-C sensor with 24MP offers a similar pixel count to the existing 4/3 sensor but offers better DR and high iso:
Coming from a Mavic 2 Pro that would mean almost a full stop more DR which would be a welcome improvement, I don't find the 20MP anywhere near as limiting as the DR or high iso is.
Looking at the evolution of the Mavic 3 starting with the two cameras, offering a model with one camera and now currently only offering the Mavic 3 Pro with three cameras suggest that's what the bulk of the market wants.
Reactions: JeffreyS and Gazwas
Photographers just want it all! ;)
It's gained an extra stop of sensitivity as the main camera is now f2. Smaller sensors can have increased dynamic range. Just look at the super35 Canon C300 III and C70 with their DGO sensors which are equivalent to their newer gen full frame successor's.
If photographers want nothing more than increased DR, I'd wait to see what processing is on offer before righting the Mavic 4 off.
Reactions: KS-6 and Mrktn
Aren’t they looking at 13 May for release date? In which case won’t be long before it’s teaser week 😉
That's a good spot on the aperture which I'd missed although it's dynamic range I'm mostly interested in, while there are some variances dynamic range is almost entirely tied to sensor size so I doubt there's much they can do with the 4/3 sensor given the existing Sony one has good stats for the size as it is.
Reactions: Gazwas and Mrktn
Deviating from this a little, read somewhere that the fixed nd filters will not be ready. Do you reckon these will be sold separately when they’re ready and fitted by the user or will they already be assembled as shipped but not activated until a future FW update? They’ll be electronic nd filters, right?
We've seen picture of fixed (8, 16, 32, 64) ND filters so I think those are coming and will be an optional extra at some point.
If you mean the electronic variable ND that was rumoured not being ready, I'm not sure it even exists.
The trouble with leaked DJI info is that it always comes from China and so much gets mixed up in translation.
At this stage, to me the variable bit sounds most likely to mean the various lens filter density is different to give the same strength ND effect on all three lenses like the Freewell ones. There doesn't seem to be any electronic contacts on the filterless gimbal images we've seen and if it's an unreleased built in future feature why would you need optional clip on ones.
However, this might change tomorrow as we get closer to launch so its anyones guess. 😄
Reactions: Mrktn
God knows Gaz 😂the picture seems to change every couple of days. Only way of knowing for sure is release date
Reactions: Gazwas
It looks like they will use probably a stacked sensor,probably Quad Bayer again to get the 100 effective MP sensor. It probably is somewhere around a true 25 MP sensor.Sounds like all three camera sensors will be stacked.Not exactly what I was hoping for but who knows maybe they will work out great.
So will it have the same image quality problems at the QB resolution of 100 Mp as the Air 3S does at the QB res of 50 Mp?
Mini 4 Pro, Air 3 and Air 3s all perform similar so we can only assume it will have similar issues looking at their current track record.
On the Air 3 I don't see any difference in image detail in the 12Mpix standard capture upscaled compared to shooting in the 48Mpix mode. Some say the Air 3s is an improvement but plenty here still complain about image artefacts.
It could be down to lens resolving power which hopefully the Mavic 4 improves on but we won't know until release. 🍿
Which 4/3 sensor is it likely to be? I've not been following the recent sensors DJI have been using, Olympus use a Sony 20MP quad bayer sensor in the OM-1 II and the OM-3 from what I can see while the Panasonic GH7 uses a 25MP sensor that isn't quad bayer.
F2? I can't wait to see how those corners stack up, lol!
I do not expect greatness but because it is now 28mm it should have less optical distortion than the 24mm to begin with thus less software correction required. Let's not forget that the corner softness on the previous 24mm lens was to a large degree caused by the software correction (embedded lens profile) stretching the corners out of the frame, and making them look blurry in the process.
There are some samples here, DNG, the 28mm seems to have rather soft corners, speaking in terms of absolute photography. I would say the corners are much softer than with my 1/1.32" 25mm smarphone DNG samples, alas those are 12MP not 100MP, but I am refering to what I see in the 25MP samples from the link.
I am not too impressed with the sharpness of the 168mm lens, could have been a bit better, this lens while in vertical mode would help me get the architectural details I am looking to capture.
I am debating weather to get this it or not.
I only downloaded and processed in Lr the very first shot of the Tallinn Old Town, the 25MP version. While it looks pretty good on the first sight upon closer scrutiny at 100% on my monitor the first thing I've noticed was the blurry zone on right side of the frame where the white church tower is. That is very concerning. Then I looked closely at the fine organic details in the image.. The fine tree twigs, foliage and even the rockwall stone blocks remind me of a watercolor painting. The micro details are smudged and not present. I understand that to most people this is nitpicking and inconsequential. But from a purely photographer's perspective this "digital overprocessed look" is not looking all that good to me.
I'm sorry to be harsh, but these are simply horrendous results.
Optically the lens is a mush. And something went terribly wrong with 100->25 mpx quad bayer binning. I see the same very strange color patch issues that @Filmarik has noticed. Look at the out of focus rendering on the ferry boat and buildings next to it. I hope at least the binning issue is firmware-fixable.
Optics may be early QA problems, but I fear it's just badly designed. There are also weird chromatic aberrations on the gold crosses on the cathedral - looks like some digital CA corrector tries to suppress them.
Sailor Sea
