Stuck update - SOLVED
ecoleman
I've never had any issues before with firmware updates. Today I'm trying to get the latest firmware installed .800 but it failed 3 times through the IOS app.
So, now I'm on my Mac and have successfully updated the remote via Assistant.
I've also sucessfully connected the Mavic to Assistant and it has flagged up that NFZ need to be updated. I've confirmed that and it downloaded something within a few seconds.
Now I'm sitting at a "Transmitting...." screen. Have been here for 10 odd minutes and it's still at 0%.
It did this before and I restarted everything an tried again but by this time my battery had run down below 50% so had to swap out the battery. I've started it again but the same issue. It just sits at 0% when transmitting the NFZ data.
Is this normal. Should I just wait?
Solved. Just ignored the NFZ update and went on to the firmware update which went through smoothly.
I had that same problem with version .800:
I was also stuck at 99% during the upgrade to version .900, I unplugged and plugged back USB cable and it worked for me. I instantly saw a message "complete", and asked me for updating NFZ database, without restarting I could notice in the app upgraded version of the aircraft and the controller. Remember to update all batteries.
The Grumpus
