Sunset,cows,hot air balloon!
DevonDrone
Devon UK
A quick mix of last nights flight, nice sunset and a hot air balloon :)
You Know. I was all set to comment and say that all you needed was a litter of spring puppies and kittens and people would go nuts with your video.... then your puppy showed up. Nicely done!
Reactions: DevonDrone
Although nothing bad happened I'd suggest keeping higher above the cows as they can get spooked, go into stampede mode and bad things will happen.
Bear in mind each of those animals is worth around £1000 minimum!
I point this out mainly for others thinking cows (or horses) will make good subjects and just ignore it - they often do but if one or two get alarmed it is dangerous.
I wouldn't fly over my own at that height because I know what they are like, and have seen them rampage through fences and get hurt cramming through gates when scared by other novel but harmless things.
Many thanks :) everyone loves puppies!!
Many thanks for the concern and point taken, I fly alongside them often and always looking to see if it bothers them but they seem to be fine, but still a valid comment :) it was also higher than it looks in the vid!
tabarton94
