Tablet holder compatibility
jwt873
Manitoba, Canada
After my first two M2 flights, I've decided that I can't stand using a phone to fly.. I need to press my 9.7" iPad Pro into service, so now I'm looking for a tablet adapter.
Just about all of the adapters I've seen on the net are for earlier versions of Mavic controllers. (The Pro & Air). I've never seen a controller from an earlier Mavic, so I can't visualize the sizes of them. I imagine they are the same size, but, before ordering, I'd just like to confirm that the phone grip dimensions are the same or close to those on the Mavic 2 and that controller will be able to clamp on the base of the tablet adapter..
Thanks in advance...
You might not need an adapter if it is the same size as the ipad mini, you can just stretch out the legs and it will fit.
Edit: Sorry, the ipad mini is apparently 7.9" so it won't work.
Mavmount 3 works well with the 9.7 iPad. Just make sure to get the right pad clamp; the skinny one does not work if your pad is in a case.
I really appreciate your efforts with this great program. Helps a lot to visualize the flight; it is just too bad that the framing by Litchi is so sloppy. Things often look better in the Virtual Mission than the actual mission footage due to the framing drift.
venoom2001
