The drone DJI mini 1 after the accident. Stabilizer and imu errors
viktor_2258
Kowel
Good day everyone, today I am dealing with the DJI mini 1 drone. The fact is that recently it flew into a tree, after which we got the error "failed to start barometer. restart drone code: 30047". Then they tried to repair it themselves, but the 3-in-1 loop was damaged during assembly. After that, the drone gives the following errors: "Unable to connect the stabilizer, contact DJI support for repair. code: 40012" and "starting and extracting data on the IMU. code: 30066". I tried to replace the 3 in 1 loop, but the error did not disappear, I also replaced the IMU module. but, unfortunately, it didn't help either. I am asking for your help, I will be grateful for every answer, tell me where to look for a malfunction and what else I can diagnose.
If the connector on the main board is damaged then I think they are looking at a replacement second hand drone, it's probably the cheapest option especially if you are charging them for your time. If you replace the main board then the camera and gimbal will need to be re-paired/recalibrated to the new main board and that needs some scripts down loaded from Git-hub? and the use of python. From memory it also leaves a residual warning message.
the connector on the main board is intact, only the cable was damaged, I have already replaced it with a new one
Fair enough, but if the gimbal is involved in the errors I still think replacing the drone may well be the cheapest option.
I like DIY repairs myself but, unless you have a stock of known good second hand parts, guess work purchases can amount and need not fix the problem.
If you yourself are an amateur repairer then the old drone may be of some value to you, motor. arms shell etc. I have a "sold for parts" mini 2 that I reshelled from a 'spare shell I had 'lying about'.
Of course you could try
Reactions: Cafguy
hey i found the fix from some german guy and it worked for me , so long story short i had that issue after changing the flex cable the way to fix it is , there's a chip on the flex cable the thin and long one which sits on the side of the drone you will have to desolder the chip from old flex cable and resolder it on the new flex cable i got it done from a phone repairing shop you just need the old chip on the new cable and then it should work and errors will go away automatically
Robby1983
