"There’s a problem with this drive. Scan the drive now and fix it"
DroneTech
Every time I connect the Mavic to my PC I get the "There’s a problem with this drive. Scan the drive now and fix it" message? Anyone else get this message? I tried formatting the sd card in the Mavic but it still shows up. The sd card works fine.
Just ignore it and use the SD card into the computer itself.
Do you use the Assistant at all when doing upgrades and does that go through ok.
Yes I use Assistant 2 without any issues. So what is the reason I get the error message?
Ok, I got that when I first connected mine.
I just ignored it and now just put the SD straight into computer.
I didn't want to take a chance of bricking it if my computer decided to do something to it.
If it works ok in the Assistant that's good.
Just don't let your comp "fix" the drive.
I get the same issue no matter what sd card I insert in the computer. Noticed you live in Wollongong, I live there also:)
Reactions: Michael Ainsworth
Interceptor650
