Third battery light blinking after charging
jamesgb
After charging the third battery light is blinking twice every second or so. (The light that is two away from the battery power button). I've read online that this means over charge? I put it in the mavic and checked the cell levels and they are at 4.32, 4.24, and 4.34 with a total voltage of 12.95. So a little out of balance...
Another battery that is charging normally is reporting 4.32, 4.34, 4.31 with a total voltage of 12.98.
Based on the voltage it doesn't appear to have been over charged.
Any ideas?
Thanks,
James
Copied this from Mavic manual"
Yes, as I mentioned in my post, I know that it means over charge. However, when I checked the charge level via the app the battery does not appear to be over charged.
Chatted with DJI support. They said to drain the battery to 0% and then try recharging...
dvkhamtruocsinh
