TimeLapse Help
Tonyxgr
Does someone know how to "send" my MP on a precise spot of sky everyday in order to create a timelapse ?
Here is a good video describing the process. You can find a lot additional information on this forum.
Reactions: Dunc08 and tiparoch
Not sure if i can find the same coordinates like this ....but thanks for your reply
I m not sure if i m covered by insurance if something goes wrong on these apps :(
I see your point. You must be very careful with these applications as pilot errors do occur especially when missions are poorly planned or battery life is not taken into account. Good luck in your search.
A simple waypoint mission in Go 4 should work. Have a little more in the frame than you need and you can crop the pictures to maintain the same (or similar) position.
You also need to adjust for different lighting conditions from day-to-day. Use the histogram to check brightness and shoot in RAW to have more correction ability in post processing. I do not know what the best starting point for white balance would be. Perhaps someone else can chime in about that.
Reactions: ksmusa
Simplest thing I think is the Litchi App! You can program the flight Before you fly
Reactions: ksmusa
Mamanov Ramazan
