Timelapse video and photo over month
TNielsen
Denmark
Hi
We must have made a big addition to our company building over the next months. I would like to send my Mavic Air in the air and take photo and video every week, and put it together for a video at the end.
My plan was to use Autopilot, and waypoint, and fly the same trip. Does anyone have comments and experiences with that.
Hi. I posed a similar question 8-10 months ago and Litchi was the recommendation, which I took. Originally I wanted to take a daily image of my home from three vantage points. I created "missions" that took 7 sequential images of each of the three points of interest. By taking a sequential 7 I was able to select the "best" of the seven, assuming variances in position that may have been influenced by weather (wind, etc.) or variations in GPS readings. The weather has proven to be a barrier to the idealistic 'daily' part of the project (record rain, rain, rain thru out the spring summer fall), but I'm still getting pretty consistent images. Well worth the $22 (US) I spent. Not done yet, though.
Thanks a lot for your answer. Out building project takes more than a year, and I think I then will try to make a "mission" that takes an orbit video, some pass true video, and a Rocket video of the building process and then some pictures with some nice angles. As you say, the weather can be the problem, but if i run the "mission" once a week, i have to try to find timeslut with dry and come weather.
Here's a How To on YouTube that saved me from purchase of additional software as I already own LR (photography is a keen interest). If I may suggest as you go along with your project a few things;
1. Try manual settings which can be accomplished with the aid of your Histogram. This should assist in keeping most of your exposures similar due to changing weather etc.
2. As you are shooting this experiment on a different project with different settings of your time lapse itself- 1sec, 2sec or more time differences. I found 2 sec interval @ 24fps really not to my liking, at least on this one project I was doing. I plan to try @30fps.
3. YouTube is your friend as well as these forums. Do searches in each and explore some of the results trying to find something you like.
3. Create a check list so you perform the very same tasks each time. Noting is worse that you've captured good footage only to realize you forget to focus/over-exposed etc.
Keep in mind the duration you are speaking of- over the course of a year. Weather will make a difference and should be intersting so be sure to capture more than you need. You won't be able to go back and reshot but you can always edit out stuff you already have.
The sun will be changing positions as well so shooting at the same time each day may or may not be all that important. Again, depends on the look you want. Since you are doing multiple shots that could aid in making things even more interesting.
Just some thoughts. Here's the link-
Reactions: TNielsen
famagusta
