Trouble making changes stick
royster
Put the P3A on hold while I fire up the just delivered Mavic Pro, my issue is on first fire up, I go into the menu ,set RTH, multiple mods & when I back out of this menu I loose my settings, what am I doing wrong?
using a asus tablet as monitor,
The setting should stay, they do get erased when you do a firmware upgrade.
Yes, connected of course, there are similarities between the Phantom line & Mavic's, so the learning curve is not as steep, if one has flown a DJI machine before. Anyway, That's what I;m telling myself.
I think it has to do with the menu on the Asus, i.e.- I hit return to home spot to type in 40 meters, keyboard comes up, then back out to go to next change, when I loose the keyboard, I think I;m erasing the RTH # I just added,will try again, oddly, its not raining!
Mamanov Ramazan
