Trying to activate??
BigAl KY
I am "dumb" After flying P4 and P4+, I thought I would try the Mavic. So I have everything all set up, but I do not see the screen to activate it? I have gone over numerous times to no avail. So what am I missing? Is there a step by step by step instructions somewhere that I don't see or find?
Thanks for your help:)
Al
What do you see in DJI GO 4 when you start it up?
It seems the remote controller is not connected to your mobile device. Try removing the cable from the remote controller on the left side and connect a cable to the USB port on the bottom of the remote controller.
Be sure to unplug anything plugged into the side of the remote.... when using the bottom center access.
That is done. I need to find the page where it allows me to activate the Mavic. I am just baffled.
Hmmmm I guess I am trying all routes. Just need to find the page to activate the Mavic.
Are you using Go or Go4. Mavic only works with Go4. Are you sure the Mavic and the remote is paired together?
Hi, dumb question but did you presed once and again press and hold power button on mavic remote to power it. I just got Mavic and had this kind of silly problem.
Best regards
Lukas
Any idea what fixed it?
srchipiron
