On the right track, but math is wrong. The new canvas should be 18884x9442px, twice as wide as it is high, using all the original horizontal resolution.You will have to resize the canvas to 3146x6292. Make sure you resize the canvas so the current photo is at the bottom of the canvas. From the there you will need to "fake" the sky to fill it in the blank area.
Opps, I read his size wrong so my math was wrong. I don't spend a lot of time filling in the sky as I figure not a lot of people are going to be looking straight up. While this is far from perfect this is what a couple of minutes filling in can do. I use gimp for the photo editing.On the right track, but math is wrong. The new canvas should be 18884x9442px, twice as wide as it is high, using all the original horizontal resolution.
Thanks, can you outline the specific steps to do this (in Photoshop)?You will have to resize the canvas to 3146x6292. Make sure you resize the canvas so the current photo is at the bottom of the canvas. From the there you will need to "fake" the sky to fill it in the blank area.
Thanks Kilrah. And how do you then save it with the correct metadata, so that it is recognised as a 360 spherical pano?Open in PS, resize canvas, select to expand upwards, enter size (with 2:1 aspect ratio), select new empty area, content-aware fill.
If you are on Windows, right click on the saved file, select the details tab. Find the metadata you want to change/enter, click on it and you can enter what you want. SaveThanks Kilrah. And how do you then save it with the correct metadata, so that it is recognised as a 360 spherical pano?
Brill, thanks.If you are on Windows, right click on the saved file, select the details tab. Find the metadata you want to change/enter, click on it and you can enter what you want. Save
Camera Maker - RicohBrill, thanks.
(Hopefully) last question... what is the correct metadata to insert?
Thank you, I'll try that.Camera Maker - Ricoh
Camera Model - Ricoh Theta S
Just had to look into it, and exiftool as explained here worked fine: Editing 360 Photos & Injecting Metadata » Eric ChengBrill, thanks.
Thanks for the update, that's very helpful [emoji106]Just had to look into it, and exiftool as explained here worked fine: Editing 360 Photos & Injecting Metadata » Eric Cheng
