Two cryptic settings
kona
What are these two settings?
1. Under "HD" there's a "Switch to HD" mode. When I set this to 1080p (which I assumed just means video will stream in 1080p instead of 720p to the remote) there's a pop-up message saying "Recording Resolution is automatically switched to 1080p". What does that mean?
2. Under "General Settings" there's an option for "Long Press" under Camera. The options are "Gimbal Control" and "Focusing". What do these mean?
Thank you.
Reactions: SteveNunez
Thank you.
1. is quality of live feed to your mobile/pad device. If you choose 1080p, you lose the ability to record 4K, however, the cached and stream will be 1080p quality. The warning pops up to tell you that you will default to 1080p for recording. Goto the record menu and nominate 2.7K. Now you can record in 2.7K AND have 1080p stream/cached live feed.
2. Test it out. if you set to GIMBAL CONTROL and long press on your screen, it will move the camera up ad down. If you set to FOCUSING, then long press on screen will control the Focus.
Reactions: kona
It would be cool if focus peaking only enabled itself when you are adjusting the manual focus
attifko22
