Ultimate App to merge DJI and GOPRO files
pkoi
panama
DJI/GoPro Merger — Technical Overview
This macOS desktop app automates organizing and merging your DJI drone and GoPro .mp4 clips into clean, continuous videos — without re-encoding.
✅ Purpose
Merge dozens of small clips recorded by DJI drones or GoPro cameras — files like DJI_0123.MP4, MAX_0123.MP4, or GX0123.MP4 — into larger files for smooth editing or archiving.
⚙️ How It Works
1️⃣ Scan & Filter
  • [] You choose a folder or drive.
    [] App scans all subfolders for .mp4 files.
    [] Only files with names starting DJI_, MAX_, or GX are matched.
    [] Size checks:
    DJI_: under 4GB
    GX and MAX_: under 12GB
  • App saves: full path, prefix, size, creation date, parent folder.
2️⃣ Grouping
  • [] Files are sorted by folder and creation time.
    [] A group must:
    Have the same prefix.
    Be in the same folder.
    Have clips within a configurable time gap (default: 15 min).
3️⃣ Tree View Interface
  • [] Groups are shown as a tree structure.
    [] Parent: shows prefix, first-last index, total size, date.
    [] Children: full paths for each file.
    [] Double-click a file to open its folder.
  • Select/deselect groups or individual files.
4️⃣ Pre-Merge Organization
  • When you start merging:
    App makes a MERGE folder.
    Inside it, a PREMERGE folder.
    Each group gets its own subfolder named like the final output.
    Selected source files are moved there.
    A file list for FFmpeg is built.
5️⃣ FFmpeg Merge
  • [] Runs:
    Code:
    ffmpeg -f concat -safe 0 -i filelist.txt -c copy outputfile.mp4
    [] -c copy: no re-encoding, lossless.
    [] Output is named:
    PREFIX_first-last_DATE.mp4
    [] Example: DJI_002-005_20240630.mp4
    [] Log file saved with the same name: DJI_002-005_20240630.log
    [] Sets the output file’s timestamp to match the first clip.
📁 Folder Result
Code:
ROOT/
├─ MERGE/
│ ├─ PREMERGE/
│ │ ├─ DJI_002-005_20240630/
│ │ │ ├─ DJI_002.MP4
│ │ │ ├─ DJI_003.MP4
│ │ │ ├─ DJI_004.MP4
│ │ │ ├─ DJI_005.MP4
│ ├─ DJI_002-005_20240630.mp4
│ ├─ DJI_002-005_20240630.log
🔧 Technical Stack
  • [] Python 3 + PyQt5 for the desktop GUI.
    [] os, pathlib, shutil: file operations.
    [] subprocess: run FFmpeg.
    [] os.utime: adjust timestamps.
Perfect for: drone pilots, action cam owners, vloggers — anyone needing a clean, automated way to batch-merge clips losslessly.
Reactions: mavic3usa
Nice. What about the proxy files? Can it merge those too *and* rename the extension so it can be used in DR?
newts540
