Understanding IMU strength menu
Rcdude1990
Hey guys quick question cause I feel a little confused
So the IMU strength menu I guess you can say... shows like the legend of green = great.
My question is, there's a bar I see... is that bar suppose to be fully green? Cause mine had like less than a quarter full green and the rest was blank...
Should it be full greeen? If it it and it's only a little green should I calibrate?
Reactions: wheels
You will understand the display better if you take the Mavic in your hand and tilt or turn it.
You'll see the different graphs grow and shrink based on the amount of tilt in the different axis'.
Green color actually means that the signal is valid and of good quality.
Reactions: wheels
Gotcha will do! I check before flight so it's not in the air hence I guess why it's only a tiny bit green
Correct. all bars should be almost off if perfectly level
Shorter = better. When it reaches a certain length it will turn yellow, then red.
RichardThiery
