Update Iphone 8s too?
photo2be
Stockholm Swedem
Hi. everything works great when I use my MiniIpad or the bigger one. I have updated to latest firmware and I have the new "compass". But when I use my Iphone 8s I only get the "old" compass. When I check firmware when using Iphone 8s the screen says I have the latest firmware. Am I doing something wrong? BTW the 8s is updated yeasterday.
Do the minipad and 8s show that they have the same App version installed?
Update the iPhone DJI Fly App on your 8s, that should bring up the new compass. But then again you may want to keep the old compass because it shows the correct orientation.
Reactions: A.O.
I fly with an iPad mini, it has the new indicator, my iPhone 7 still has the old version on it as well due to not being updated.. And no... I will not be updating it!!
Hi Pillius,
Both the AC and RC has the same and latest updates. The Ipad's has app version 1.2.2 and the 8s 1.2.0.
IF I will update the 8s should I then delete the 1.2.0 and then reinstall the 1.2.2??
Seems like I should keep the old version until they have fixed 1.2.2. ?
I wouldn't update but that's just me.
My iphones are on something like 1.1.3 & 1.1.5? (battery flat so can not check) and I want unencrypted logs etc.. That probably is not a relevant consideration with the mini 2.
That said when I have updated an Android device the process (removal? of the old version)? was automated, I would guess IOS is the same.
Reactions: A.O.
Hi Paleomanjim, where / how do I update the iPhone DJI Fly App in my 8s?
Visit AppStore, click on the icon on the top right corner (AFAIR on iOS up to 12.x there was a tab called Updates) and you should see the list of the apps that can be updated. Alternatively, just search "DJI Fly" and you should see a button "UPDATE".
Thanx Tibzee!
Dimension Drone AZ
