Upgrading from Mavic to Mavic 2 Pro
Hi. I'm an FAA certified pilot upgrading from Mavic to Mavic 2 Pro. I'm used to using an ipad with DJI Go 4 App with the original Mavic. Are there any special steps I need to take to begin using the DJI Go 4 App with the new Mavic 2 Pro? Do I need second "instance" of the app to be installed/linked to the new drone, or do I need to uninstall the existing App and start fresh? Will I still be able to operate the old drone with the ipad or will I be taking the old drone out of commission? Any help will be greatly appreciated. Thanks!
Reactions: Former Member
Also, if you want to continue flying your MP, same thing goes. DJI makes it very convenient for you to switch birds and not have to use different apps.
The only DJI birds that cant use DJI Go 4 are the legacy birds prior to the Phantom 4, but they can still use DJI Go. In that case you would have to use 2 different apps.
Most helpful! Thanks again.
Guillaumeb89
