Vibrating gimbal
Bajaja
Mavic Air 2
Tohle dělá můj MA2, když ho zapnu.
Kalibrovaný gimbal, kalibrace IMU, nejnovější firmware letadla a ovladače, nic nepomohlo.
Nikdy nespadl.
Setkal se již někdo s touto závadou?
jak to opravit?
Díky za radu
Google Translate:
Calibrated gimbal, IMU calibration, the latest aircraft firmware and drivers, nothing helped.
He never fell.
Has anyone ever encountered this defect?
how to fix it?
Thanks for advice
Is this drone new ? (Sticker was still on)
It’s motors are running on the table, could be causing the vibration / gimbal problem.
Does it also do this in flight ?
Has it flown before without the problem ?
Could be propellers slightly damaged, chipped, not balanced ?
They are stock OEM props, no upgrades or changes ?
Inspect, and maybe replace these to see if it eliminates the problem.
It was purchased on August 26, 2020
The disorder appeared about a month ago, until then without problems.
Everything is original from purchase.
Only about twice in the beginning, I forgot to remove the gimbal cover when starting
The vibrations take place only a few seconds after the aircraft is switched on, then they stop, see video.
Sorry to hear about this. I do hope you get it sorted. Re gimbal cover removal I have attached a big black on white label to the front of my MA2 saying (REMOVE COVER)! That should work!
Switch the drone off.
Twiddle the camera and gimbal from stop to stop in all directions to check for free movement.
It looks like the camera pitch is at fault so twiddle the camera up and down.
You might also try using an air pump to blow into the camera hinges/motor.
I use a large air bed pump.
Free any blockage so the camera moves freely and then recalibrate the gimbal.
Still no joy then try this
I only watched the video yesterday on the phone, but can see now the motors weren't started up even.
Not something I think will be easy to solve, late Aug 2020, is it still under warranty ??
I think DJI or an authorised repairer will be required, somehow I feel it will be a new gimbal / gimbal motor required.
Try the gimbal cleaning tips mentioned above though, free movement etc, and info in the video linked there (post #8).
Jrwooley4
