Vision sensor
Timpaxi
Hi!
Just wanted to ask if someone has like broken main board with vision sensors then i would like to buy one. I need lence for the second sensor in bottom. Something went to that lence and can't make it clear. When try to calibrate via assistant, picture is blurry and it won't calibrate.
Never looked at sending anything internationally before
I'll price it up next time I'm off work which is Friday
Is it easy to change if change whole sensor instead only that lence.. Well, it's easy to change lence only since it's threaded
Its easier to change the lens but it'll be setting the focus that could be hard whereas a camera with lens will be set
Also as its so small it's just as easy to send with the camera
It's glued to the board, right? The camera? Can it be taken out without breaking the board
The camera cover is glued and screwed
It's a hard glue so after the cover is unscrewed it cracked off easily using a flat screwdriver and levering it up pivoting off the metal can next to it
Ok, but if just change the lence it can be focused with dji assistant calibration tool. Cos it shows the image from those cameras and turning the lence to make it clear
Hi! I have the same problem. Who can help and send me the two downward sensors? I'll pay for sensors and for mailing.
what's wrong with them? Are you sure you need both?
Its not a part that anyone is doing so if you need both then you will have to buy a new core board
my copter touched a bit of sea water, a day later I dismantled and cleaned it. Everything works, but the downward sensors show a very blurry image, so I can not do the calibration.
Could it just need cleaning? Possible water or condensation on the lens
I tried different ways, but nothing helps. Maybe the salt has penetrated the glass of the sensor matrix, but I think I will not be able to clean it .. Probably have to order the main board
4Gabe
