water damaged advice
Moss99
cornwall , UK
Problem? water damage
Was unit in a crash? yes into water , no sign of impact damage
What have you tried so far? cleaning with ipa and ultrasonic
What device are you using ( iphone , ipad, Samsung , etc)? iphone
What firmware are you running ( aircraft, remote controller)? no remote as of yet
What Go app version are you using? N/A
Any modification?
(if so what) no
Did you change anything or install any apps? (if so what) no
Do you have a video or pictures of the problem? (if so post link) No, but can take some if it helps .
Hi all , new to the forums .
i have a water damaged mavic pro , it looks like the core lower board has taken the worst of the damage although under the shields it looks ok , i have given it a good clean with ipa and put it through an ultrasonic cleaner (avoiding the cameras and ultrasonic sensors) although the camera lenses dont look too good , im assuming these cant be replaced as they seem fairly well bonded to the board .
I was thinking i may try to get a replacement board to be safe , the esc board looks like it got off quite lightly it seems to have a lot of conformal coating ( great idea) .
what is the best course of action , put it all back together and see what doesn't work or try to power on without the various boards attached ,.
thanks.
Badeff
