waypoints was there then "firmware inconsistency" and it disappeared
dougputt
Hi
Having issue with Mavic 2 pro and the latest release .0300 upgraded to that and was looking forward to programming a route but after first flight then a battery change I got "firmware inconsistency" so it reloaded or downgraded and when I restarted the waypoints option is missing!!! Tried using the DJI assistant to refresh it but waypoints still missing....downgraded to previous version then tried to reload newest version but to no avail.
Anyone?
Best
D
Hi
Anyone?
Best
D
Hi Doug, as you were saying.. after changing battery, did you upgrade your battery via the App? Your batteries must all be updated to latest as well. Check your drone by connecting it to your PC or laptop via DJI Assistant and there you can see the version you currently have in your drone.
Hope it helps.
JAKE
I recently upgraded my Mavic 2 Pro firmware and the DJI Go app with one battery in the craft. I have used my second battery with no issues or warnings. Should I have received a warning?
djipilot55
