Weak Transmission Signal
D Berry
China Spring, TX
When flying my MP Platinum it seems that each time I get out about 2k feet I get ‘Weak Transmission Signal-Adjust Antenna’ msg on the controller. Is this normal or anything to be concerned about? Thanks
Where are you flying?, do you have a clear LOS, or do you have obstacles in front, say trees, buildings? Out in a field, with no trees, you should get easy 1 mile and possible 2. 10500 feet is my best on a MPP. It gave up the ghost at that distance and disconnected and started a RTH. Quickly reconnected however. I normally never fly out that far, as my main goal is photography, and at that distance, you have very little time to do anything but turn around and come back. I only use the stock controller, no antennae add ons or boosters, or changed out antenna. for some of the after market stuff.
I am in Arkansas, and with the MPP, I never have signal issues with distances at 2000 feet. Rarely do I have a 100% LOS, having to fly over near by trees.
Couple of thoughts, what is your height? You can fly up to 400 feet now and the higher the better signal strength at least this is what I have found. Lower to the ground at distance will kill of your signal very fast.
What is your signal 5.8 or 2.4, the MPP for me is better at distance at 2.4. You can take it Auto and peg it to 5.8 or 2.4 only, just to see. In the wild outside of the city, I prefer 2.4, but around the city, I find that 5.8 is better.
Of course you are I am sure pointing the controller towards the direction of the drone and keeping the antenna upwards?
Lastly, what are your signal strength bars showing, when get the message? Best for signal and HD (your video coming back) is 5 bars. When you see the signal warning, what are the bars? You can see this on both your DJIGO4 screen at the top and on the controller screen again at the top. I ask this because I have seen this same message, but I still have 5 bars of signal, which never drop. I am more focused on the signal strength bars.
If you fly near another MPP, MP, M2 Pro, or even a Phantom 4 Vr 2.0, you can get signal strength warnings. A lot of people say they often fly next to another pilot, however every time I am within 10 to 20 feet of a friend with a active controller, I tend to get the same warning. And this one I do pay attention to as a conflict from another controller can be IMO a show stopped, and all you have to do is move about 5 to 8 feet away.
Paul C
Paul,
Thank you for the quick response and for the feedback. I admittedly freaked out when it happened and quickly turned it around and headed back before noticing some of the things you mentioned. Because of some smaller airports in the area My altitude was probably around 125 ft so that may have a lot to do with it plus there are numerous trees. I will be more vigilant the next time it happens. Thanks again for your help!
RGG
