weird gimbal movement
abdu_mka
Portland
Hi All,
a couple of days ago I experienced weird gimbal movement, I have PolarPro 64ND filter on the camera and it has never been an issue.
can someone please take a look at the video and let me know if there is anything I should worry about.
Hi All,
Easy way to narrow it down, take the filter off and see if you have the same vibration when flying
Check too that the vibration plate is not hooked up somehow. It can jump out of place. Should be hanging properly and feel “loose”. You could accidentally do this when installing a filter, or it can happen in an accident/strong wind buffet/unpacking etc.
There is something clearly wrong. It looks like a mechanical problem in the gimbal assembly. As previously suggested, take the filter off, and retest. Then check the gimbal assembly itself for free movement and constrictions.
BigPapa98
