Weird Issue VLM and Google Earth Movies
Bussty
New Zealand (Queenstown)
Site
andrewbusst.wixsite.com
I'm pretty sure this is a Google Earth issue bit I have used VLM to create the KLM file so thought somebody here may have some experience to help solve.
The issue is it appears even though I can plot a perfectly well behaved flight in Litchi via VLM and import that to Google Earth Pro, when I go to make a Movie in GEP it renders perfectly except for a weird few frames when it gets to the end of the lake (see attached) and suddenly it's like the altitude jumps down to ground level then soars up to like 300-500m!
It's really weird as there is a KLM line going across the lake between two Waypoints and the Waypoints are not any where near the area where it abruptly changes altitude. It's as though there is a tear in the mapping of Google Earth?
This is a Google Drive Link which contains a short movie showing the issue (the original edited much longer movie cutting out the blip is here
) and the Google Earth KMZ and VLM generated KLM file for the path of that movie.
The public small Litchi Flight Path of the effected are is here Mission Hub - Litchi
Hopefully somebody can offer some help?
Many thanks in advance
Bussty
EDIT: I Just tried a short manual sequence of same flight in Google Earth Studio and flies fine (note KML file loaded as overlay so flight path similar. You can see that small clip here Google Studio Clip
I am afraid I have no insight into the significant blips that appear in this simulation. They are definitely there, and unlike anything I have seen in VLM. Is it possible to change way points significantly (for example, delete them and substitute nearby locations) to check whether this is just some Google incorrect estimate of ground height?
One other thought: in the early part of the mission, where the drone goes over mountain forests, have you definitely taken the height of the trees into account? It is not always clear whether Google is giving ground height or terrain height...
Reactions: Bussty
Thanks for having a look but I have sorted. I was using the Google Extension rather than standalone VLM 2.7.1 as soon as I started using that everything was perfect :-)
dvkhamtruocsinh
