What does it means? "Critically Low Voltage. Aircraft will land" with 62% battery left
psechi
Recusei com 60% de bateria, e após cerca de 1 minuto de vôo, a uma altura de 50 metros, a bateria indicou 0% e recebi esta mensagem. Ele começou a pousar sozinho e eu não pude evitar. Por sorte estava perto. O que é isso?
Please upload your TXT flight log here and post the link back here.
Also, if you know English, it would be most helpful if you would write in English since that's the language of this forum.
Reactions: everBit
Assuming that his native tongue is Portuguese, here’s the Google translate effort:
I declined with 60% battery, and after about 1 minute of flight, at a height of 50 meters, the battery indicated 0% and I received this message. He started to land alone and I could not help it. Luckily it was close. What is it?
Rolling Horizons
