When to replace blades?
Bad Santa
After my last flight I did an inspection of my blades and thought I felt a small nick in all of the blades at the same spot. Turns out it was the branding letters.
But then running my finger along the blade I could feel small imperfections on the edge. Tried hard to capture them in pictures.
The question is, how do you know when to replace blades with "normal wear"?
For reference, I only have a little more than an hour on my drone so I'm pretty sure I haven't worn the blades out yet.
Is this damage from striking something solid?
Props don't really "wear" since they are only (supposed to be) striking air.
However, you should absolutely replace a prop if it strikes a solid object, as this can compromise the integrity of the hub or cause cracks. Additionally, check for hairline cracks or other signs of damage around the hub area. If you spot any, it's time for a replacement.
As for the edges of the prop, minor imperfections like the ones you shared wouldn't typically warrant replacement unless they're the result of an impact. That said, if replacing them gives you peace of mind, go for it.
Some people prefer to change their props on a regular schedule (e.g. after a certain number of flights), regardless of damage. I've never followed that myself since it feels a bit wasteful unless there's an actual issue.
Reactions: Cafguy
I haven't hit anything but a few blades of grass and the needles of the tree on it's first flight. I did a check after it getting stuck in the tree and the blades didn't have any damage.
I don't know where those nicks came from unless I hit a bug :eek:
I did have a bird attempt an attack but it never got closer than 5 feet.
Could it be that these are just normal imperfections, and the close-up photo makes them look worse than they actually are?
It's not uncommon for new DJI props to have slight imperfections straight out of the package. Many (all?) of mine do. These imperfections are usually so minor that they have no noticeable impact on flight performance.
Reactions: Cafguy and Rchawks
It could be. I just didn't see them when I did my post-tree inspection.
Have you ever built plastic model kits? What's around the leading and trailing edge of the blade is 'flash' and happens during the injection moulding process when the two parts of the die aren't registered perfectly. It is not a necessary part of the blade structure, very thin and can deform (fold) very easily to give the appearance of damage.
I replace them once a year on my main drone, which is about 150-200 hours of flight time or so in my case. The props are the only thing keeping the drone flying, it's like the rubber and brakes on a car, but more critical, so don't wait to see the degradation to change them; you shouldn't use them more than 200h or so.
Appart from cutting grass, hitting branches or chopping insects, the props wear on five main points, which all occur at a really slow rate:
  1. The edge of the blade. The air is not the void, it's full of suspended particles that will wear the edge through time, on dusty environments the degradation will be quicker.
  2. New blades have a bit of vertical movement around the rivet, and it increases with time as the plastic wears away with vibration and the forces applied while flying. With time, it will affect the angle at which the props rotate, acquiring a kind of "reverse umbrella" form.
  3. Degradation of the material due to oxidation and UV, as flights are performed on the outside. Props are quite resistant, but no plastic (or material) is immune.
  4. Oxidation of the rivet, specially if you fly near the sea.
  5. Bending of the props while the drone is carried around on the bag, or with the strap that holds the props together. The props will slowly bend and acquire a new curvature due to the pressure applied by the prop strap.
So in resume, a good-looking prop should be changed after around 200 hours or once a year, but ofc if your drone is just sitting in the bag forever, like my Mini 2 for example, it's not worth the cost.
PS: Props with missing parts or dents should be changed asap, as the blades rotate at high rpm, so if they are not balanced the vibrations generated will stress the motor and the prop itself, which will lead to a midflight crash.
Pay attention to the props, but also, don't become a paranoid, as they are quite tough and most drones can fly with heavily degraded props.
The material you see at both edges is(as previously mentioned)a result of the injection mold process. If you are very careful, that material can be removed by scraping with an Exacto knife or a razor blade. That very minor amount of material being removed, if done correctly, will not affect the balance of that prop. There should be a VERY SLIGHT difference in its performance.
Reactions: Rchawks
I was thinking of using some 600 grit sandpaper to smooth out the molding flash. In 4 yrs I've only changed had to change blades once on a mm due to warping of the blades that cause an error. Every single one of my flights has been from a landing pad for launching and landing. Never had any contact with objects. Except for the mm, haven't had any errors due to prop warping.
If you are going to do any sanding or removing of stuff from your props..Best to get yourself one of these.
Looking at my A3S edges there is molding flash I have been thinking about smoothing it out but haven't got to it.
marcusjohn3684
