Where to buy USB C Cable?
Scampcamp
I need a USB C cable for my Mavic Air controller that plugs into my Galaxy S10 phone.
Are the generic versions ok or should I buy from DJI's website? Thanks
Incase you can't find the correct cable then you can use a OTG cable on controller end and a normal data cable to connect to your phone.
I got same problem and made a new cable by cutting and connecting both
Make sure you get a data cable, and not just a charging cable. I get my cables from Amazon.com. When you search for a cable, have them sorted by customer review, and look at not just the average score, but also the number of reviews (the number in parenthesis). Look for strain relief at the connectors. Also, consider ones marked as AmazonChoice, which are high value (not necessarily expensive), and have low return rates, etc.
mini3user
