Which channel 2.6 or 5.2?
Glen e
Fort Lauderdale
or whatever the two numbers are exactly… Does anybody have a link to a thread or info that explains when you should use either one of these? Am I correct that you should choose the 5.6 if you're in cluttered urban areas because a lot of routers use the 2.6?
My understanding is it's best to leave the transmitter in Auto. The transmitter will give you a visual warning if there is a caution situation with strong Wi-Fi interference.
I don't fly inside. However, if I need to turn on my Mavic inside I remove the propellers due to always receiving the "Warning. Strong Wi-Fi signal Area. Fly with Caution" in my home.
zotacreborn
