Why did my Mavic 2 zoom fall out of the sky
is this the one?
Yeah ... that's the one.
My belief is that this was due to a HW failure ...
The barometric & height readings went really strange around 300sec. Fault messages regarding Barometer noise & Barometer error starts to occur in loads in the log.
At 375sec no Altitude or height data agrees...
Over time this start to effect other systems & more faults pop up in the log regarding other IMU errors like Craft ctrl failure, Height ctrl failure. About at 375sec a VPS reading for 3,42m height comes (note the height reading there) and all 4 motors are then effected ... even pitch, roll & yaw (didn't add those to minimize the spaghetti :rolleyes: ) goes haywire from there ... probably there it hits the trees or ground & tumble.
This wasn't a commanded descent ... your throttle & elevator inputs below. First VPS reading & crash moment marked in the chart.
And then the reason for this ..?
It could have been the temp... as it certainly must have been colder on higher altitudes ... or something else that caused the HW fault, perhaps somebody else chimes in which more accurate can pinpoint the reason.
Sorry, it has been a while since I posted. Thank you so much for the work you put into this! What is HW?
Humbug4
