S Shark New Member Joined Feb 27, 2019 Messages 1 Reactions 0 Feb 27, 2019 #1 it will spontaneously go on for about 30 seconds and then say the aircraft isn't connected
brett8883 Well-Known Member Joined Jan 10, 2019 Messages 6,234 Reactions 5,330 Location Salt Lake City, Utah Feb 27, 2019 #2 Is this in WiFi or to the remote?
Starz Well-Known Member Premium Pilot Joined Dec 26, 2016 Messages 5,643 Reactions 4,708 Location Arizona Feb 27, 2019 #3 Probably a cable issue. Use a different one and see if that solves the problem. A little more info on what you’re doing will help. Reactions: brett8883
S Superjam Member Joined Oct 14, 2016 Messages 21 Reactions 21 Age 56 Feb 28, 2019 #4 I had a similar problem and replaced the cable that connects the remote to the phone. Problem solved.
